Activity Forums Maxon Cinema 4D “Close polygon hole” leaves weird waves in the surface
  • “Close polygon hole” leaves weird waves in the surface
    Posted by Dezső Szűcs on November 27, 2020 at 3:26 pm
    So I have this waterdrop shaped lathe object that I want to cut in half, but when I use the “close polygon hole” tool on it, the surface isn’t flat. When I tried doing the same thing to a sphere, it worked perfectly.
    What could be the problem?
    Thanks in advance!
    Dezső Szűcs replied 5 years, 9 months ago 2 Members · 2 Replies
  • Justin Thomson
    November 27, 2020 at 6:07 pm
    You’ll need to add some new “edges” to poly created to fill the whole. Why not just use a Boole that includes the Lathe object and a Cube?
  • Dezső Szűcs
    November 30, 2020 at 7:33 am
    Well, I didn’t know that tool exists, but I gave it a try and it worked perfectly.
    Thanks for the help!
