Activity Forums Maxon Cinema 4D cloning with multiple materials
  • cloning with multiple materials
    Posted by Cody Campbell on February 6, 2012 at 7:42 pm
    I want to put an object in a cloner and have each instance use a different material. I suppose I could drop the object into the cloner multiple times each with a separate material… But is there a way to just use the object once and then have to cloner assign the material per instance?
    Just because noone understands you does not make you an artist
    Cody Campbell replied 14 years, 7 months ago 2 Members · 2 Replies
