Activity › Forums › Broadcasting › cloning to HDCAM-SR
  • cloning to HDCAM-SR
    Posted by Scott Warren on September 5, 2008 at 6:59 pm
    I am trying now to clone to HDCAM-SR from a D5.
    on the SR deck my TC settings are as follows:
    EXT-L
    TC SOURCE-REGEN
    TCR Select – LITC
    RUN MODE – REC.
    Am I missing something?? I have the TC patched correctly as well. To my knowledge, it should be pulling the TC from the D5 with these set.
    “Live in the Beauty of your own reality.”
    Scott Warren replied 18 years ago 2 Members · 2 Replies
  • Joey Burnham
    September 11, 2008 at 8:43 pm
    You have it on External LTC / SLAVE yeah?
  • Scott Warren
    September 12, 2008 at 12:24 am
    that is what I was having it set to. EXT LTC/SLAVE. It would not accurately pull the timecode from the other deck. I would get the warning message: EXT LTC NOT READ.
    I finally figured out that if it were to be set to, S LTC it would read the other decks timecode accurately. I don’t have any idea why or how this is happening but as long as I am getting accurate timecode cloned, with out errors, then I am going to go along with it. so basically, the steps as described in the manual, were of no use.
    As a test, I patched the HDCAM deck to a Digibeta, using a DC but still keeping the TC. It cloned it just fine.
