Cloning objects in 3D
I suspect this is going to be more of a scripting question but should be fairly simple.
I have a single 3D layer which I would like to clone a number of times with a particular Z-axis offset so when looking through the active camera it appears that the domino-like row of the objects descends into infinity. I will be digging around Javascript and AE’s object classes and methods tonight, but I’m suspecting this should be a fairly easy script to put together. Can anyone point me in the right direction on this one?
Thanks in advance.
