Activity Forums Apple Final Cut Pro Legacy Cloning External Hard Drive
  • Cloning External Hard Drive
    Posted by Randolph Harrison on May 12, 2014 at 4:01 pm
    Hello All,
    First, I would like to thank you in advance for any advice or suggestions.
    I am going to be editing an indie film on Final Cut Pro 7. The problem is, I’m currently working in a third world country with almost no support for anything Mac-based. I have two pretty old Western Digital My Book Hard Drives… I will be using one for all of my footage for this film… but because they are old, and I can’t get a hold of a new drive here, I feel that I need to have an exact clone of my work on the second drive, just in case. Is there any software which is cheap (or free), which I can update daily with my work. I want to be able to switch drives, in case of an emergency without losing anything.
    Thank you again.
    Randy Harrison
    Macbook Pro 17″, i5, 2.53ghz, 8 gigs ram
    OSX 10.9.2
    FCP 7
    2 x WD My Book
    Mark Suszko replied 12 years, 3 months ago 3 Members · 3 Replies
  • Mark Suszko
    May 13, 2014 at 4:26 pm
    Try Carbon Copy Cloner?
  • Eric Strand
    May 14, 2014 at 1:45 pm
    You could use Terminal and RSync at the end of each day. Only copies over what has changed. I’m not any sort of heavy terminal user, I just learned through googling.
    In terminal you type:
    rsync -av –progress source drive destination drive
    @ericstrand11
  • Randolph Harrison
    May 16, 2014 at 12:43 am
    Thank you very much, I’ll check into all of that.
