Cloning effect problem.
Posted by Steven Toozer on January 23, 2012 at 8:16 pmHello.
I have managed to clone myself and it looks brilliant but as soon as I had a filter you can see the line where I have masked the video.
Here is the picture
https://imageshack.us/photo/my-images/823/clonel.jpg/Is there a way to remove this line, the line only appears once I add a color filter.
Many thanks.
James Houghtaling replied 14 years, 7 months ago 3 Members · 7 Replies -
Mike Kujbida
January 23, 2012 at 10:07 pmTwo things for you to try.
#1. Increase the feathering in the mask.
#2. Apply the color filter to the events before applying the mask. -
Steven Toozer
January 23, 2012 at 10:22 pmThanks for the reply but unfortunately I have tried what you suggested but the line is still there 🙁
James Houghtaling
January 25, 2012 at 1:42 amIf you already tried to drag the order of the pan/crop and filter which should fix the problem, you can try adding your filter to the project instead of the event.
My Hardware:
Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM Win7 64bit.My Software:
Vegas Pro V11 with Boris Continuum Complete 7, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff. -
James Houghtaling
January 25, 2012 at 9:03 pmSorry, I should have said make it a Video Output FX which applies the effect or filter to the entire project. Of course you may have to keyframe it in and out if you don’t want that filter on other events in your project.
My Hardware:
Steven Toozer
January 26, 2012 at 9:12 pmYou are a legend my friend, it’s fixed!!! Thanks so much!!!
James Houghtaling
January 26, 2012 at 9:22 pmI guess there’s always more than one way to skin a cat… if you hate cats that is. 🙂 Best of luck with your project.
My Hardware:
