Activity Forums Maxon Cinema 4D Cloners – collision without gravity
  • Cloners – collision without gravity
    Posted by Craig Whitaker on April 18, 2011 at 2:06 pm
    Hey everyone,
    Working on a medical animation where I need to show cells slowly moving around as the camera pulls back. I have a setup right now using a cloner grid with random noise for a slow, undulating move. When I set it as a rigid body, it obviously falls to the ground. I’ve seen people using the Force option to set to “follow position” but no matter what setting that’s on, the clones are quite spastic. Is there a good technique that will allow cloners to simply not intersect while randomly moving around?
    Thank you,
    Craig
    craig whitaker
    vfx – mograph
    David Gugel replied 9 years ago 4 Members · 3 Replies
  • Michael Szalapski
    April 18, 2011 at 2:25 pm
    Could you lower the force of the gravity so they don’t fall?
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Adam Trachtenberg
    April 19, 2011 at 4:06 am
    Try turning gravity to 0 in project settings and also turn up follow position and follow rotation in the rigid body tag’s Force tab. The higher the value the less dynamic interaction you will get, but I think collisions are respected even at high force settings.
  • David Gugel
    September 17, 2017 at 1:29 am
    Thank you! I know this is an old thread but that answered my question and solved my problem.
    Much appreciated, David
