Activity Forums Maxon Cinema 4D Cloner within cloner, randomize all – how?
  • Cloner within cloner, randomize all – how?
    Posted by Brian Murphy on August 29, 2018 at 8:11 pm
    Hey guys, if you have a different way to do this, please let me know…
    I have a cloner cloning a line of spheres on an object (think of a curvey line with spheres attached to it. I then need to clone that curvy line of spheres downward so it becomes a curtain of spheres from the curved line.
    NOW, I need to randomize each and every sphere, offset them just a bit. If I do it to the first cloner, each sphere gets randomized…good, but then that whole thing gets cloned from there.
    If I put the random effector in the second cloner (the one within the first cloner), it clones the random offset of each sphere from the first cloner and I get straight lines of spheres all the way down.
    Keep in mind that I need that first line of spheres to attach to the line as that line will change in shape and I need the cloners to follow it as it animates.
    Again, I need to randomize all spheres…any ideas?
    Thank you!
    Brian
    Brian Murphy replied 7 years, 11 months ago 3 Members · 3 Replies
  • Emir Bojorquez
    August 29, 2018 at 9:28 pm
    You could try to clone the spline like this example.
    I hope it helps.
    12680_exampleclones.c4d.zip
    Good Luck
    Imagination is the best tool…
  • Brian Jones
    August 29, 2018 at 11:27 pm
    or clone onto an invisible polygon sheet with a single cloner then random those clones
  • Brian Murphy
    September 3, 2018 at 6:38 pm
    Thank you, both!
    I’ll experiment with both methods.
    Brian
