Cloner with complex shape – Application out of memory – “Render Instance” is checked
Hey all,
I have several cloners that are cloning an x-ref object (of a molecule), in a couple cases, they are referencing an instance of a group of the x-ref as I have those ones animating within that group. All the cloner objects have “Render Instances” checked, even the instances have it checked. I continue to get halted renders as my Mac kicks back “your application has run out of memory”, usually after about 30 – 40 frames.
I’m stumped at this point – any ideas?
I’m on a Trash can Mac Pro 12 core with 16GB RAM but it’s happened with other machines (older Mac Pro towers, 12 cores, 32GB RAM) too.
-Brian
