Activity Forums Maxon Cinema 4D Cloner with 2 Blend splines distort instances
  • Cloner with 2 Blend splines distort instances
    Posted by Denys Glagoliev on December 28, 2019 at 11:35 am
    Hello, could you please help me with one issue with Mograph Cloner:
    1. I want to model one figure and then have a possibility to animate it with Bend (x,y-axis) and Step (z-axis) Effectors.
    2. I could model this figuers by make two splines, combine them and convert to Mospline to add more point for bending. Then add Bend effector o the Null group – ite ok, but in this case can not animate it by step effector in Z-axis:
    3. Then I try to add two splines (was converted from mosplines whith “Even” method points interpolation) in Mograph Cloner, but Cloner distorts original splines.
    4. Without dividing splines Bend do not works properly:
    Denys Glagoliev replied 6 years, 8 months ago 1 Member · 2 Replies
  • Denys Glagoliev
    December 28, 2019 at 11:43 am
    I think I found the path – just devide subsplines ☺
  • Denys Glagoliev
    December 28, 2019 at 11:45 am
    I think I found the path – just subdevide splines ☺
