Activity Forums Maxon Cinema 4D Cloner Varying Offset
  • Cloner Varying Offset
    Posted by Nick Smith on January 23, 2017 at 11:05 am
    So this might be a complicated one, and most likely impossible, but here goes.
    Is there a way to have a repeated different offset using the cloner, that still allows the individual clones to be manipulated by the effectors?
    Example; I want to repeat say, a cube, but have it off set first by 20cm, then the next one by 10cm, and then back to 20cm and so on and so forth. Is this possible or am I delving into the realms of python/coffee?
    Just a thought, thanks 🙂
    Nick Smith
    \”So long, and thanks for all the fish.\”
    http://www.anarkyanimations.co.uk
    Brian Jones replied 9 years, 8 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    January 23, 2017 at 8:32 pm
    You could do the offset with a Step Effector and use the effector’s spline graph to set the distances, but it would be a bit laborious if you have a lot of clones.
  • Brian Jones
    January 24, 2017 at 4:45 am
    I saw this in a video somewhere (a Siggraph feed maybe) can’t find it but it was the formula effector to affect every second clone. Took a while to work it out… in the formula – if(mod(id;2)=1;1;2) takes the clone id number, does a modulo (basically a division) by 2 then gives the integer remainder, if it = 1 it’s an odd number, if not it’s even. The 1;2 means multiply the Parameter numbers by 1 or 2 respectively depending on the result of the mod(ulo) those could be any value.
    10985_evenoddclonesformulaeffector.c4d.zip
