Activity Forums Maxon Cinema 4D Cloner & Symmetry break external comp tags?
  • Cloner & Symmetry break external comp tags?
    Posted by Craig Whitaker on May 17, 2012 at 2:46 pm
    Hello everyone,
    I have a hallway with a group of lcds that rotate as the camera passes them. Each block consists of 4 lcds, each with an external compositing tag. When the clone is activated, the external comp tags do not create solids for AE, nor when I place the clone into a symmetry object.
    Any ideas?
    Craig
    craig whitaker
    vfx – mograph
    https://www.imdb.com/name/nm4117151/
    Adam Lincoln replied 14 years, 3 months ago 3 Members · 2 Replies
  • Adam Trachtenberg
    May 17, 2012 at 5:21 pm
    Put the external compositing tag on the cloner instead of on the cloned objects.
  • Adam Lincoln
    May 18, 2012 at 1:55 pm
    when attaching an external compositing tag to an animated symmetry object this also doesn’t work?
    sorry any ideas still?
    Adz 🙂
