Activity Forums Maxon Cinema 4D Cloner & Spline Wrap unwanted movement
  • Cloner & Spline Wrap unwanted movement
    Posted by Joey Campbell on February 6, 2013 at 4:12 pm
    Hi – after a lot of tweaking and help/advice from forum members I’ve managed to get this 99% the way I want. There is one slight bug which is causing the object to ‘pop’ or move. If you scrub the timeline between 48-58 frames you’ll see the movement I’m talking about.
    Does anyone have any idea what could be causing this or how to remove this movement ?
    5386_ucomplete.c4d.zip
    Joey Campbell replied 13 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    February 6, 2013 at 4:47 pm
    in the SplineWrap (AsplineWrap) go to Object/Spline (the Spline controls at the bottom, not the Spline name slot at the top) make sure Fix Bounding Box is checked. The spline wrap tries to keep objects centered on the spline and your object is changing shape all the time so it moves it (at 48-58 it’s really sharp but it moves slowly back from 70 – 90 as the U closes up) Fix Bounding Box is the cure.
  • Joey Campbell
    February 6, 2013 at 5:01 pm
    Excellent – thanks Brian
