Activity Forums Maxon Cinema 4D Cloner, Radom and those Darn Textures
  • Cloner, Radom and those Darn Textures
    Posted by Tom Dempsey on February 5, 2015 at 3:17 pm
    Hello and thanks in advance for anyone willing to help on this issue. I have gone through web searches
    and tutorials and have yet to find a suitable answer to this newbie problem. I’m setting up a grid array with the cloner of 4x4x4 cubes. I’m using a rigid body tag on the cloner to drop the cubes onto a floor. all works well on that front. However, ultimately i would like to have a different photo on each face of every cube.
    is this possible? i don’t mind if it’s time consuming. just something that works.
    Best,
    tomd
    tom dempsey
    Tom Dempsey replied 11 years, 7 months ago 2 Members · 4 Replies
  • Cassius Marques
    February 5, 2015 at 3:51 pm
    Do you know how to put one photo on each face of a single cube?
    If you do, just keep duplicating the materials, changing the photos and duplicating the cubes inside the cloner and adding the materials to them… you don’t have to clone a single cube, the cloner object can have several cubes inside it…
  • Tom Dempsey
    February 5, 2015 at 4:11 pm
    Hi Cassius,
    Thanks for the suggestion. I would like to ask if this would make a difference. I would like a cube
    that has the same photo on all six sides. Then, the cubes all rotate individually to reveal a different photo on all sides.
    much appreciated,
    tomd
    tom dempsey
  • Cassius Marques
    February 6, 2015 at 11:30 am
    Its all the same, just change, apply and animate the materials as they rotate (use the alpha channel).
  • Tom Dempsey
    February 6, 2015 at 3:29 pm
    Excellent! Thanks so much for the help.
    best
    tomd
    tom dempsey
