Activity Forums Maxon Cinema 4D cloner and random effector noob query
  • cloner and random effector noob query
    Posted by Manojit Ghose on April 24, 2012 at 12:52 pm
    hi everyone
    Uploaded with ImageShack.us
    Uploaded with [URL=https://imageshack.us]ImageShack.us[/URL]
    i want the clone objects to appear on all the edges as i scale the falloff, with visibility on for the second random effector.
    however it doesnt seem to work as it is supposed to.
    any tips?
    thanks
    MG
    Siddharth Gautam singh replied 14 years, 4 months ago 2 Members · 1 Reply
  • Siddharth Gautam singh
    April 25, 2012 at 8:25 am
    This setup is not working as the Random Effector is just randomizing the visibility of the clones… So the clones out side the fall off are not randomized and hence are visible.
    This is my solution:
    Use a Plain Effector instead of the Random Effector with the same falloff and the visibility box checked.
    In the Effector tab of the Plain Effector, Change Max to -100 and Min to 100.
    You will see that the clones in within the falloff disappear. Invert the falloff.
    Then apply a Random Effector.
    Uncheck everything in the Parameter and increase the weight transform to 100.
    Create a box fall off just big enough to contain the other falloff.
    Invert the falloff.
    This should sort you out.
    Siddharth G Singh
    Film | Motion | Illustration
    http://www.siddharthgsingh.com
