Activity Forums Adobe After Effects Clone/Mirror multiple layers in 3D?
  • Clone/Mirror multiple layers in 3D?
    Posted by Brian Tetamore on November 30, 2008 at 1:52 am
    I have a 3d project where I need to clone several layers and then mirror them. The idea is that the camera would move across (Left to Right) a looping landscape in the background. I’m assuming that in order to “loop” the mountains/background, the left edge must match the right edge as far as the image. Hopefully that made sense.
    Is there a way to do this? Maybe there’s an easier way?
    The Visual Rabbi
    Don Sciore replied 17 years, 9 months ago 3 Members · 4 Replies
  • Scott Roberts
    November 30, 2008 at 7:47 am
    Clone them all by slecting them and hitting control-d to duplicate your layers. Keep those new ones selected and pull up the transform properties to mirror them.
    Color Grading presets for After Effects, Premiere, etc., plus free presets and more.
    LITTLE BLACK BIRD – PROFESSIONAL VISUAL EFFECTS
    https://www.littleblackbird.com
  • Don Sciore
    November 30, 2008 at 5:13 pm
    Hi Brian,
    If I am understanding you correctly:
    You can actually do this with only one photo. Drop your BG photo into a comp. Apply Effects>Distort>Offset. Change X position to the middle of the comp/ Use the Clone tool to remove your seam (now in the middle). Then duplicate the layer>move it to the left or right edge. Parent it to the first layer.
    At 00:00 set position KF for layer 1. Move out a couple of seconds and move the layers X position value so that layer 2 is full on screen. End your work area there. Page Down 1 frame and move the 2nd KF there. That way the last frame is also your first frame. Ram preview and you have a seamless loop.
    Looping Background.
    Once the left and right edges were the same, you could also just use CC Repetile to duplicate the image.
    Good Luck-Don
  • Brian Tetamore
    December 1, 2008 at 4:11 am
    The mirror effect doesn’t quite seem to work. I’m probably not explaining this very well. The post from Don Sciore on looping a single image is the right idea.
    The problem is that I’m hoping to create the illusion that the Camera is moving Right to Left/Tracking along a landscape in a looped sequence. So, the end result would be the same as a looped still image, HOWEVER, I have multiple layers in 3D that form the landscape (mountains and trees) with snow falling.
    Is this effect not possible?
    The Visual Rabbi
  • Don Sciore
    December 2, 2008 at 4:53 am
    Absolutely. Just Pre-Compose the layers and follow the same process.
    Good Luck.
    Don
