Activity Forums Maxon Cinema 4D Cloned objects along a spline with a surface deformer rotating around spline
  • Cloned objects along a spline with a surface deformer rotating around spline
    Posted by Alan Chamberlain on February 2, 2020 at 1:37 am
    I’m creating a string of oil booms floating in the water. The water is made wavy with a displacer.
    I clone the boom along the spine and use a surface deformer on the spline. This works well to a point. All the booms are individual and don’t bend but instead follow the spline. So far so good. Here’s the problem, if I use the “align to spline” function in the cloner, the booms are in the right place in a string just like I want and it’s bobbing up and down on the water…however the booms are rotating around the spline instead of staying up/down with the seam on top.
    I’ve tried everything from rails to effectors, but maybe my whole approach is wrong. Any thoughts?
    Sam Treadway replied 6 years, 6 months ago 2 Members · 4 Replies
  • Sam Treadway
    February 3, 2020 at 3:29 am
    Create an instance object (modeling menu) and point it to the displaced spline object. In the Cloner, reference the instance object as the Rail. Then pull the instance object straight up until there is no jitter in the clones. Also, on the Cloner maker sure “Fix Clones” is off.
  • Sam Treadway
    February 3, 2020 at 3:30 am
  • Alan Chamberlain
    February 3, 2020 at 6:23 am
    That looks like it worked. Finally…thanks so much Sam. Don’t know how many hours I tossed at this.
    You helped me out on a model for my short film a few years ago…. don’t know if you remember, but thanks again for that as well.
  • Sam Treadway
    February 3, 2020 at 2:21 pm
    Cool. Yeah I didn’t look at the name of the poster until after I responded but recognized the name. I think the film was called Judges, right?
