Activity Forums Adobe After Effects Clone tool / motion tracking
  • Clone tool / motion tracking
    Posted by Ben1971 on January 15, 2007 at 5:37 pm
    Hello
    I have a tracking shot which pans across a wood panel background. I’m trying to use the clone tool to correct a defect on the wood panel, but as the shot pans the cloned area stays staionary and the defect in revealed. Is it possible to generate keyframes with the motion tracker and apply them to the clone tool so the defect is covered throughout the camera move?
    many thanks
    Ben
    Ben1971 replied 19 years, 7 months ago 3 Members · 5 Replies
  • Tony Kloiber
    January 15, 2007 at 6:05 pm
    I’d like to hear what people have to say about this as well.
    For the time being, you could duplicate the layer and draw a mask around a clean part of the panel. Track the original and apply to a null. Position the duplicate with the mask over the part you want to cover on the original and parent to the null.
    TonyTony
  • Ben1971
    January 15, 2007 at 6:42 pm
    Thanks Tony I did what you suggested,
    I have a question though, the clean wooden background (from the duplicated layer within the mask) changes as the shot pans and is really noticeable. How do I keep the same piece of wood within the mask.
    Many thanks again
    ben
  • Mike Clasby
    January 15, 2007 at 6:49 pm
    This adobe tut is not on a pan shot, but it does show how to use the clone with tracker points, so it should work for you.
    From one, make two (or none)
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100328&xml=ae65ttmake2
  • Tony Kloiber
    January 15, 2007 at 10:01 pm
    You could make the footage a still frame (might have a difference in noise).
    If your spot is visible the whole time you could take the tacking info and stabilize the masked layer. This should just remove the pan from the shot. Keep in mind that the tracking point should be in the area you used in the mask.
    The Tut looks promising but it only played for ten seconds.
    TonyTony
  • Ben1971
    January 16, 2007 at 11:14 am
    I went down the still image route in the end. It works pretty well so thanks again.
    Mike, thanks for the tutorial.
    ben
