Activity › Forums › Adobe After Effects › Clone stamp? Removing Burn-in Time Code
  • Clone stamp? Removing Burn-in Time Code
    Posted by Dan Mcguire on June 21, 2012 at 1:19 am
    Folks, I hope this is an after-effects question. Definitely an Adobe question.
    I lost an original tape and all I have is a VHS version with BITC (Burn-in Time Code). I want to use several clips from this interview – and wonder if there is some way to retouch the footage that can be automated. the TC appears over a regular surface – a brick wall, but also over the moving head of the interviewee.
    Any suggestions greatly appreciated. I assume I might need to export footage to PS and automate commands – perhaps clone stamp?
    Thanks very much.
    DAN
    Roland R. kahlenberg replied 14 years, 3 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    June 21, 2012 at 9:26 pm
    It’s going to take a long time and if you’ve not done stuff like this before there is a 90% chance that it’ll turn out bad. If there isn’t a budget to outsource this then perhaps a cleaned up freeze frame coupled with the SOT will suffice.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Dan Mcguire
    June 21, 2012 at 9:58 pm
    What is an SOT?
    June 21, 2012 at 10:36 pm
    Sound on Tape.
    Cheers
    RoRK
