Activity Forums Maxon Cinema 4D Clone Character Tool
  • Clone Character Tool
    Posted by Stephen Turcotte on March 17, 2012 at 3:06 pm
    I have a character that I’ve animated using the Character tool and I’d like to clone this figure so that I have a grid of people walking.
    So far I haven’t had any luck with the Cloner, I’m thinking that maybe it doesn’t work with the character tool. Any ideas?
    Stephen Turcotte replied 14 years, 5 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    March 17, 2012 at 4:43 pm
    I think you have to bake the CMotion animation before you can clone the animated character. The easiest way to do that is to use the Animate>Add Motion Clip command. So, select your character mesh, run the command, and when the dialogue box pops up, leave the default settings but check the PLA box. Then delete the skin deformer. Now you should be able to clone the animated character (check the cloner’s “render instances” box to speed things up).
  • Stephen Turcotte
    March 17, 2012 at 9:06 pm
    Good call, that worked perfectly.
    Much appreciated!
