Activity › Forums › Adobe After Effects › Clock – Numbers Effect – Shifting
  • Clock – Numbers Effect – Shifting
    Posted by Chris Tompkins on August 17, 2012 at 2:28 pm
    Is there an option (I can’t find it) that will lock in place the display.
    The Colon : I want to remain stationary while the time counts.
    Don’t like the shifting from single digit to double digit as seen here in this video sample:
    Time Numbers Filter
    Chris Tompkins
    Video Atlanta LLC
    Chris Tompkins replied 14 years, 1 month ago 2 Members · 2 Replies
  • John Cuevas
    August 17, 2012 at 2:49 pm
    Are you using the Numbers effect? If so go into the options and right justify the text.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Chris Tompkins
    August 17, 2012 at 2:52 pm
    Yes.
    And Duh!
    And Thank You Very Much!!
    Chris Tompkins
    Video Atlanta LLC
