Activity Forums Apple Final Cut Pro Legacy ClipWrap not working in Final Cut 7
  • ClipWrap not working in Final Cut 7
    Posted by David Mayer on April 26, 2014 at 10:58 pm
    I converted an AVCHD clip shot at 60i with my Canon C100 with ClipWrap (2.6.7 just downloaded) to ProRes 422. In Final Cut 7.0.3 it looks great but stutters badly. Fix?
    iMac 2.8 GHz Intel Core i7, 8 GB
    OS 10.6.8
    Final Cut Pro 7.0
    Mike Woodworth replied 12 years, 4 months ago 3 Members · 5 Replies
  • Shane Ross
    April 27, 2014 at 12:34 am
    Step through frame by frame…how does it look?
    Shane
    Little Frog Post
  • David Mayer
    April 27, 2014 at 12:58 pm
    Shane,
    Thanks for the reply. Looks like I just got nervous. I rebooted everything and let the hard drive
    rest for 10 min. and it works OK now.
    But it brings up the larger question – is it just plain silly to keep using Final Cut 7 in the HD world?
    OS 10.6.8
    Final Cut Pro 7.0
  • Shane Ross
    April 28, 2014 at 4:49 am
    [david mayer] “But it brings up the larger question – is it just plain silly to keep using Final Cut 7 in the HD world?”
    No. it’s fine to use as long as it’s compatible with the cameras and the workflow and delivery methods that you need to employ. I know many people still using FCP 7. The issue is if you want to use current camera tech, you either need to get a current NLE, or use software workarounds to enable you to use your favorite software.
    Shane
    Little Frog Post
  • David Mayer
    April 28, 2014 at 11:04 am
    Well, my workarounds so far include MPEG Streamclip for the DSLR and Clipwrap for the C100 and they seem to be doing the trick. Moving forward, what will I not be able to do – what cameras will I not be able to use?
    OS 10.6.8
    Final Cut Pro 7.0
  • Mike Woodworth
    April 28, 2014 at 6:53 pm
    David,
    You didn’t mention in your original post if you were rewrapping or transcoding your footage in ClipWrap. For FCP7 we recommend transcoding to ProRes 422.
    Also, if you like ClipWrap, keep an eye out for our upcoming solution for DSLR footage – https://www.divergentmedia.com/editready
    mike
    Mike Woodworth
    mike@divergentmedia.com
