Activity Forums Adobe Premiere Pro Clips with a green bar get a red bar when I move them on top of each other
  • Clips with a green bar get a red bar when I move them on top of each other
    Posted by Leevun Vanhove on July 16, 2014 at 11:23 am
    Hello,
    I’m working on a music clip for which I filmed on several locations. I’ve made several sequences per location, and rendered them so that they all have a green bar on top of the sequence to be able to preview it, and work fluently.
    Now, afterwards, I’ve put per sequence (per location) everything on one video track, and copied them all to one sequence, to start to edit on the final clip. Unfortunately, sometimes, when I put rendered clips with a green bar on top of each other, the bar gets red again? Re-rendering again won’t help, because I want to edit, and when I will move the clip again it will turn out red again.
    At first, I was thinking my clips haven’t got an opacity of 100%, but that isn’t the problem.
    Has anybody an idea?
    Lieven
    Leevun Vanhove replied 12 years, 1 month ago 3 Members · 9 Replies
  • 9 Replies
  • Richard Knight
    July 16, 2014 at 3:37 pm
    This is the way it works, after rendering if anything is changed you will have to render that portion again.
  • Leevun Vanhove
    July 16, 2014 at 5:54 pm
    Hi Richard,
    Thank you for your help and your reply.
    I”m convinced too that you should render again if you change anything (like contrast or scale etc.), but the strange thing for me is, I only copy the clip from a sequence and I paste it in another sequence on top of another clip and all of a sudden I have to render it again.
    When I make the track below the just copied clip invisible, the red bar on top of the just copied clip disappears and turns green again. So it has something to do with the fact there’s a clip below the clip (although opacity on both clips is 100%)
    Normally, that shouldn’t happen I think?
    Thank you for your help,
    Lieven
  • Leevun Vanhove
    July 16, 2014 at 6:01 pm
    Hi Richard,
    Something else: my sequences have the same settings. So it has something to do with the fact there’s a clip below the clip with the red bar.
    Thank you,
    Lieven
  • Richard Knight
    July 17, 2014 at 7:52 am
    I can have a 100% opaque video on track 2 completely covering a video on track 1. If I add lots of effects to the unseen video often I will get a red bar over that section. Premiere seems to start working out the pixel value from the lower tracks upwards even though they are covered by a video that does not need rendering.
  • Michael Krupnick
    July 17, 2014 at 8:45 am
    I think the bars indicate the SEQUENCE’s play-state of readiness, which is more than any single clip attribute. It also reflects the system;s capacity for real time playout, factoring in more parameters. If you stack two native clips, it probably flags that portion as a bigger CPU/GPU load, so it flags as a render.
  • Leevun Vanhove
    July 17, 2014 at 10:24 am
    Hi Michael,
    Thanks for your answer.
    Would this be the case even if the lower clip has a rendered preview, and a green bar in the sequence?
    Also, next to that, the lower clip doesn’t have a lot of effects, it’s just footage without any effect applied to it?
    Lieven
  • Michael Krupnick
    July 17, 2014 at 12:56 pm
    I’d guess so…stacking being an automatic flag. The only way a clip is free to move is if it’s by itself on the timeline and is the EXACT matching codec and wrapper as that of the sequence. The best way to do that is a direct export from PP, in which case when you re-import it, there won’t be a bar on it all. Even so, a bar doesn’t really impede the editing much if your system has adequate media drive speed and enough RAM to process in real time with low load. DVCCPro for instance, is pretty much as slick as standard old DV….
  • Leevun Vanhove
    July 17, 2014 at 2:44 pm
    Hi Michael,
    Hmm, perhaps the problem could be the RAM indeed…
    I’ll try to edit as much as possible on separate sequences before I copy all my clips into one sequence.
    Thank you!
    Lieven
  • Leevun Vanhove
    July 19, 2014 at 2:45 pm
    The more I’m working with it, i’m discovering more.
    The lower clip is actually a sequence of TGA’s (a slow motion with made with twixtor), I rendered a preview of it, but perhaps it’s better to export first a movie of that sequence and re-import it again in premiere, without using a preview render.
