Activity Forums Apple Final Cut Pro Legacy Clips transcoded from Compact Flash card will not allow Tape recapture
  • Clips transcoded from Compact Flash card will not allow Tape recapture
    Posted by Ricardo Amell on February 11, 2009 at 10:26 pm
    We recently purchased a Sony HVR-s270U. We recorded our footage via the Compact Flash card and Tape. We imported the clips using the Sony FCP plug in. When the clips are offline, we would like to be able to recapture the footage and clips using the tape. Since the clips were Logged and transferred originally, the Log and Caputre will not come up. Does anyone have a work around?
    Andy Mees replied 17 years, 1 month ago 4 Members · 5 Replies
  • Walter Biscardi
    February 12, 2009 at 2:30 am
    Because there is no “reel” assigned to the clips, FCP won’t recapture. There simply are no tapes associated with the project.
    If you want to recapture from tape, you’ll need to go in to the Reel column in your Browser and assign a tape to each clip.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Ricardo Amell
    February 12, 2009 at 4:31 pm
    Hi Walter,
    Thanks for your help!
    I changed to the reel name to something different but the the Log and Transfer still pops up. Now when I initially used log and transfer to bring the footage in, I did give all the clips a reel name association when in log and transfer mode. So the clips are already associated with a reel.
  • Dag Mykland
    August 20, 2009 at 11:30 am
    Hi Ricardo and Walter..
    Have you guys found any solution to this problem? I’m having the same trouble, and even though I change the reel name (which was done when logging the clips in “Log and transfer”) it still won’t recapture.
    the only thing that happens is the “log and transfer” window pops up..
    Camera: Sony Z7
    FCP: 6.0.6 and the latest sony plug-in I could find.
  • Ricardo Amell
    August 20, 2009 at 1:32 pm
    The best solution I have found is using a software called clip wrap. This converts those mpeg 2 files on the card and puts them as Quicktime HDV’s. Then you import these clips into final cut and still get to keep the timecode that was on the tape. It’s about $50 bucks and converts very fast.
  • Andy Mees
    August 20, 2009 at 1:49 pm
    Don’t use “Batch Capture” Dag, instead use the Make Offline command on your clips, then open the Log and Capture window (Cmd 8) and press the Batch button to capture the “logged” clips. See if that works.
