Activity Forums VEGAS Pro Clips shortened automatically
  • Clips shortened automatically
    Posted by Johan Lundqvist on July 26, 2009 at 5:10 pm
    I use Vegas Pro 8 and I must have changed a setting somewhere by mistake. My problem is this: If I mark some clips in the project media window – and the move all the clips at the same time to the timeline below – each and every clip is somewhat shortened. If I move the clips one by one to the timeline, this doesn’t happen. How do I move the clips all at once without them beeing shortened?
    This is not a crossfade-issue.
    Theo Van laar replied 17 years, 1 month ago 2 Members · 2 Replies
  • Johan Lundqvist
    July 26, 2009 at 5:56 pm
    I figured it out – I selected options/preferences/editing and changed cut-to-overlap conversion from 1,000 to 0,000. The strange thing is that I’ve nevered entered this menu before and still the value must have been changed somehow.
    But then my question is – what is the point of this feature (cut-to-overlap conversion)? Is it a bad thing to set it to 0,000?
  • Theo Van laar
    July 26, 2009 at 7:22 pm
    Normally I have set the overlap to zero. But when you e.g. would like to make a photoshow, setting the overlap to a value higher then zero will give automaticly a crossfade transition between the photos. In some cases very handy…
    Theo
