Activity Forums Apple Final Cut Pro Legacy Clips shift when nesting sequences
  • Clips shift when nesting sequences
    Posted by Ronald Thomas on August 11, 2008 at 7:55 pm
    I had this happen once before but I assumed I’d just done something wrong. However it’s happened again. I have a project that’s roughly 90 min. broken up into 4 shorter sequences for ease of use. Anyway, I nested them all into a main sequence and then laid TC over it for a client screener. What happens is that occasionally throughout the piece, a few clips shift. Now their time and place in the edit don’t shift, but the in and out of the original clip shifts so we’re seeing a different piece of the clip in the edit. It’s not constant throughout, but only happens to maybe 4 or 5 clips in the whole thing. When I go back and check the original sequence, the change has occurred there as well.
    Anyone have any idea why this is happening?
    FCP 6.0.2
    OSX 10.4.11
    G5 dual 1.8
    RJ Thomas
    Colin Mcquillan replied 18 years, 1 month ago 2 Members · 1 Reply
  • Colin Mcquillan
    August 11, 2008 at 9:23 pm
    I see this as well. Nests can sometimes act funky when something is dropped on top of them. I saw a lot of this on a recent project. 16 segments, each a nest, combined to one master timeline for output. Alpha transitions overlaid between some of the nests, and a few GFX overlaid at the head of a couple of the other nests. Occasionally, the nest under the GFX would play at the wrong spot, then jump to the right spot once it has passed the GFX overlay.
    To fix this before outputting the broadcast masters one of two things can happen.
    1: export the nests as self contained QT’s, then re-import then add your GFX/TCG filter,.
    or if you still need the flexibility to make changes to those nests as I did, and want those changes to be reflected into your master sequence with out having to export/import/export/import… render.. render.. so on…
    2: I found that if i put the playhead over the trouble spot, double clicked on the nest at that spot, the nest would open, then id switch back the the problem sequence and the nest would now display the right frame in the master.
    If that didn’t work as it didn’t in all cases, add a razor slice after the problem area, then bring the opacity down, then up of the problem area and re-render that spot.
    so,,, anyways,, if you don’t need to make changes to the nested sequences, your better off exporting a self contained QT before adding the TCG,, otherwise you’ll need to jump through a couple hoops!
    ***another cool way of adding TC to a screener, especially if you are going to use compressor to crunch out some web or DVD copies,, is to export self contained QT movies from FCP, then use compressor to add the TC Burn as you encode. This is super efficient especially if you have a multi-core machine set up to render in clusters…
    Colin McQuillan
    Van. B.C.
