Activity Forums Apple Final Cut Pro Clips rearranging themselves inappropriately (AKA: Selecting multiple clips the right way)
  • Clips rearranging themselves inappropriately (AKA: Selecting multiple clips the right way)
    Posted by Jason Jenkins on March 11, 2014 at 7:21 pm
    My first week using 10.1.1 and running into some weirdness. I have an 11 minute rough cut timeline, clips only in the primary at this point. 720p timeline with 1080p footage. I want to scale up every other clip to 150% to hide the edits with “focal length” changes. I’ve done this in a couple of different ways in earlier versions of FCPX. I made a Motion scale effect so I could apply the effect in one ‘swell foop’ to multiple selected clips. The downside is that there seems to be a performance hit versus the second method, which is just using the scale and position parameters within FCPX. As I recall, I was not able to select multiple clips and affect all their scale and position parameters simultaneously, in previous versions. I am now attempting to do that in 10.1.1.; or to copy and paste attributes to multiple selected clips.
    The problem: When I select multiple clips and paste attributes, or attempt to change their scale and position parameters universally, the clips rearrange themselves on the timeline, horizontally (chronologically). Not good!
    Note: As I have typed this post and experimented, I have discovered that the method of clip selection seems to cause the issue. If when command + clicking multiple clips, I inadvertently barely nudge the position of a clip, then the clips will reorder themselves according to some kind of grouping functionality. But not until I have completed the paste operation by hitting ‘paste’ or scale and position operations by hitting ‘enter’. The bottom line is that I need to command + drag over each clip for selection instead of command + clicking, in order to eliminate any clip nudging.
    Thanks for enduring my babbling while I work out my own problems 🙂
    Jason Jenkins
    Flowmotion Media
    Video production… with style!
    Check out my Mormon.org profile.
    Jason Jenkins replied 12 years, 6 months ago 2 Members · 2 Replies
  • Charlie Austin
    March 11, 2014 at 7:40 pm
    [Jason Jenkins] “The bottom line is that I need to command + drag over each clip for selection instead of command + clicking, in order to eliminate any clip nudging.”
    Try using the timeline index. It’s a much better way of selecting multiple clips, and will preclude you from accidentally moving the group. 🙂
    ~ My FCPX Babbling blog ~
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Jason Jenkins
    March 11, 2014 at 7:45 pm
    [Charlie Austin] “Try using the timeline index. It’s a much better way of selecting multiple clips, and will preclude you from accidentally moving the group. :-)”
    That works quite nicely. Thanks!
    Jason Jenkins
    Flowmotion Media
