Activity › Forums › Adobe Premiere Pro › Clips not rendering…?
  • Clips not rendering…?
    Posted by Norman Greenwood on December 3, 2009 at 3:16 am
    I have some 3GP clips that I wanted to edit in Premiere Pro CS4. I was able to render them all initially.
    I cut them up and put them in the order I wanted.
    Now 4 clips will just not render. I can select to render effects and the entire work area, but it freezes on the render window. When playback begins Premiere thinks everything has been rendered.
    When I try to export the timeline as a movie file it only renders up until the first unrendered file.
    Is there something I can do to remedy this?
    Thanks.
    Norman Greenwood replied 16 years, 9 months ago 3 Members · 3 Replies
  • Tracy Peterson
    December 3, 2009 at 7:25 am
    Is your work area set to the whole timeline?
    Tracy Peterson
    http://www.onetwomany.com
  • Jon Barrie
    December 3, 2009 at 12:15 pm
    Try to zoom all the way out on the timeline. Tap the \ key to zoom out. Double click the work area bar to force it to fit the entire edited length of the timeline. Try to render and/or export.
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Norman Greenwood
    December 3, 2009 at 9:42 pm
    I tried that, but it didn’t help.
    If I change a clip on the timeline that isn’t one of the original four clips, that will render without a problem.
    Initially there had been five clips unrendered, but after opening and closing Premiere a few times and moving the clips around, it finally rendered.
    This is really frustrating as I just wanted to create a video for my friend’s birthday.
