Activity Forums Panasonic Cameras clips losing sync
  • clips losing sync
    Posted by Nickij on August 24, 2006 at 12:42 pm
    Hi there
    I recently shot on the PAL P2 in 720p, acquired a copy of P2Log and successfully loaded all of the footage into FCP 5.0.4. The thing that is troubling me is that when I sync up sound (recorded to DAT) with vision (most takes are approx 5 mins) they play back at different speeds. I match up the clapper mark perfectly and the dialogue at the start of the sequence matches up perfectly too. But when i play the dialogue at the end of the clip, it is out of sync by as much as half a second (sound coming in before vision).
    I have converted all of the audio files from .wav format, to .aiff files but this has made no difference. Even rendering or altering the playback resolution does not alter the problem.
    Is anyone able to shed some light on the subject at all? Thanks heaps!!
    cheers
    nickij
    (Aussie P2 newbie!)
    Nickij replied 20 years ago 3 Members · 4 Replies
  • Noah Kadner
    August 24, 2006 at 1:12 pm
    What timecode setting was the DAT using? Was it a timecode DAT or something simpler.
    Noah
  • Nickij
    August 24, 2006 at 2:34 pm
    I honestly don’t know. The soundie is a pro; I didn’t ask. What do you think I should check with him?
    –nj
  • Federico Prieto
    August 24, 2006 at 4:59 pm
    Give a look to the dat audio….probably it’s at 44Khz. It must be at 48Khz….so if this is the case, make a resample to 48
  • Nickij
    August 25, 2006 at 6:15 am
    thanks, that sounds logical! I’ll give it a go and let you know what happens
    kind regards
    nickij
