Activity › Forums › Apple Final Cut Pro Legacy › Clips looks low res when droped in to a sequence
Posted by Yamir Bhatt on October 30, 2011 at 2:31 pmSo I am new to FCP. I have been working mostly in AE. I am trying to edit a small interview and the clips looks fine when i double click it. But once I bring it in a sequene and edit it, it looks low res. I looked in the RT setting and that is set to Highres in playback and frame rate, where else can I look to improve the clip quality?
Rafael Amador replied 14 years, 10 months ago 5 Members · 8 Replies -
Brad Wright
October 30, 2011 at 4:10 pmTake a look at your sequence settings. The default video options may be DV for FCP and therefore it’s resizing the video to standard definition.
Brad Wright is software engineer, so often hard to figure out what he is talking about. He is always happy to explain answers further.
Rafael Amador
October 30, 2011 at 4:21 pmPlease Yamir, a bit more of info about the footage and sequence settings.
rafael -
Steve Eisen
October 30, 2011 at 5:14 pmTo add to the above comments, you can not judge the quality from your computer monitor.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Final Cut Pro Users Group -
Brad Wright
October 30, 2011 at 10:20 pmYes, I second that. Never use your computer monitor to color correct video footage. Always use HD-SDI or firewire out to a calibrated television monitor.
David Roth weiss
October 30, 2011 at 10:22 pm[Brad Wright] “Never use your computer monitor to color correct video footage. Always use HD-SDI or firewire out to a calibrated television monitor.”
I think you forget one Brad – what happened to component out to a calibrated monitor?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comDon’t miss my new Creative Cow Podcast: Bringing “The Whale” to the Big Screen:
https://library.creativecow.net/weiss_roth_david/Podcast-Series-2-MikeParfitandSuzanneChisholm/1POST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Creative COW contributing editor and a forum host of the Business & Marketing and Apple Final Cut Pro forums.
Yamir Bhatt
October 30, 2011 at 11:28 pm -
Yamir Bhatt
October 31, 2011 at 12:09 amit was sequence setting. Missed it the first time i looked in to it
Sequence>Setting>render control> Render>…
Buya!!
Thanks All
Rafael Amador
October 31, 2011 at 3:17 am
