Activity › Forums › Apple Final Cut Pro Legacy › Clips keep crashing FCP 7 and all others. Are they corrupt?
  • Clips keep crashing FCP 7 and all others. Are they corrupt?
    Posted by Curt Milner on November 12, 2012 at 12:14 pm
    I’ve come across a problem I’ve never encountered before. I shot some footage on a HMC 150 in Full 1080/25p and Logged & Transferred the clips as normal into FCP 7 using Apple ProRes 422 to capture. I am using a SanDisk extreme 32GB to record my footage.
    Some of these clips played fine, however, a few of them (crucial to my film) will not even play in the Viewer, let alone the timeline. When I try to play these clips, the are slow to load, they beachball, play fine to a certain point then get stuck at the same point in time in the clip. They also make awful shrill noises green lines on them. Often attempting to play a clip results in Final Cut Pro crashing. The files will also get stuck at the same point in Quicktime and MPEG Streamclip, and crashed those as well. I am confused as some of the clips I shot on the same day withing minutes of each other are fine. I suspect corrupt clips but am wondering if there is any possible solution before I have to go down the re-shoot route. The clips are even crashing all Quicktime repair programs I, have tried. HELP!
    Thanks.
    Curt Milner replied 13 years, 10 months ago 2 Members · 3 Replies
  • Rafael Amador
    November 12, 2012 at 1:59 pm
    Are you able to play the original clips in the camera you shot with?
    It smell a bit to corrupted media, but if the camera clips were corrupted you probably would have had on the Log&Transfer.
    First I would try to L&T again.
    rafael
    http://www.nagavideo.com
  • Rafael Amador
    November 13, 2012 at 5:31 am
    As Dave mention, spanned clips, or that you haven’t waited enough between you hit STOP and REC again in camera.
    This causes files corruption.
    rafael
  • Curt Milner
    November 13, 2012 at 10:02 am
    Thanks Rafael, I suspect there was a problem with Log & Transfer process as well. Will look at L&T again. I have had corruption with my SD cards in the past but this has resulted in all footage being affected as opposed to individual clips.
