Activity › Forums › Apple Final Cut Pro › Clips in imported XML projects do not sync with library
  • Clips in imported XML projects do not sync with library
    Posted by Roman Semenov on February 6, 2015 at 11:35 am
    When I import XML project its clips are not marked as ‘used’ in Library.
    I’m trying to import an unfinished project from Premiere. First I import all media so that all media is tagged with folders and all unused media is present in library. Then I import xml sequence (using DaVinci to convert xml to fcpxml). Now I want to tag all used clips as favorites but the library does not show any clips as ‘used’. When I click on timeline clip and select ‘Reveal in Browser’ it jumps to correct clip. Is there a workaround?
    Bret Williams replied 11 years, 7 months ago 2 Members · 4 Replies
  • Bret Williams
    February 6, 2015 at 2:55 pm
    Do you have the function enabled?
  • Roman Semenov
    February 6, 2015 at 5:49 pm
    What function?
  • Bret Williams
    February 6, 2015 at 6:06 pm
    The one you’re looking for. Show/mark used media. It’s off by default.
  • Bret Williams
    February 7, 2015 at 5:26 am
    View>show used media ranges
