Clips FREEZE!
Very often when I try to use clips from Andrew Kramer’s Evolution, the clips freeze in After Effects. The rest of my animations will play fine. A flourish for example, will just appear without being ‘animated’ on, or it will skip lots of frames, or the content will simply disappear from the comp, while remaining on the timeline.. This happens to many different clips from the Evolution pack, and I can’t understand why?? The clips play fine in quicktime…
I tried rendering out my comp and the same happens..
Any ideas???
Thanks!!
