Activity › Forums › Adobe After Effects › Clips freeze after 7-10 seconds
  • Clips freeze after 7-10 seconds
    Posted by Ryan Moyer on January 6, 2010 at 4:15 am
    It seems like most of the clips I work on, even if they’re just text or animation presets already included in AE/Bridge, will freeze after about the 7-10 second mark.
    It’s not a rendering thing, as that section of the video shows that it is rendered. Also even if I render the video through the render queue the output freezes at the same section.
    I’m running windows, q9400 processor, 4gb ram, 8800gt graphics card.
    Ryan Moyer replied 16 years, 8 months ago 2 Members · 8 Replies
  • 8 Replies
  • Michael Szalapski
    January 6, 2010 at 4:35 am
    Do you have multiprocessing turned on in your preferences? If so, turn it off; you don\\\’t have enough RAM for it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ryan Moyer
    January 6, 2010 at 7:22 am
    No, it is turned off.
    However, my ram usage isn’t adding up. It says I have 3.25gb installed, with 0.5gb left for other applications, but has total After Effects memory usage listed at only 1.2gb.
    The Render Multiple Frames Simultaneously box is unchecked.
  • Michael Szalapski
    January 6, 2010 at 2:15 pm
    What version of Windows are you running?
    What version of AE are you running?
    Do you have the latest updates to AE?
    Do you have the latest driver for your graphics card?
    Do you have any OpenGL settings on such as rendering with the OpenGL renderer?
    – The Great Szalam
  • Ryan Moyer
    January 8, 2010 at 2:04 pm
    1) yay!
    2) It was a simple media player, but when I imported it to Vegas it was doing the same thing.
    3) Unfortunately yes, this is on a single drive. I’ve never had problems with Vegas working off a single drive but I guess that’s not true of AE and I’ll need to set up Raid or an SSD?
  • Ryan Moyer
    January 11, 2010 at 3:46 am
    Windows XP
    CS4 9.0.0.346
    Yes
    I didn’t change any of the original settings in regards to this, but when I go to preferences -> preview the enable opengl checkbox is checked, as are the two checkboxes beneath it.
  • Ryan Moyer
    January 13, 2010 at 3:42 pm
    Good info here, but I’m still a bit confused as to what action I need to actually take to fix my problem…
  • Michael Szalapski
    January 13, 2010 at 3:59 pm
    Are you saying AE freezes at the 7-10 second mark during rendering in the render queue AND when playing back RAM previews?
    What elements do you have in your comp?
    What happens if you move the work area to render from the ten second point on?
    Does this happen in all comps in all projects?
    – The Great Szalam
  • Ryan Moyer
    January 14, 2010 at 12:32 am
    Yes, in the render queue and when playing back via a ram preview, or even a regular preview.
    If I move the work area past the freeze point all I get is the frozen part. When I said 7-10 seconds I didn’t mean between the 7 and 10 second mark it is frozen and it works fine everywhere else, I meant that at some point (usually around 7, 8, 9, or 10 seconds but not always necessarily within that range) it freezes and remains frozen from that point until the end of the comp.
