Clips darkening in timeline
I’m working on a project in Premiere Pro CS4. There are a number of mov files that when I put them into the sequence they appear darker than they actually are. In the preview monitor the clips are the normal brightness and sometimes when playing or scrubbing through the sequence they are normal. When I locate the files on the drive and play them through quicktimes they are normal brightness too. But when I stop on these clips they darken up considerably. When I export the clips darken as well. The issue doesn’t always happen to all the mov clips and sometimes they will export dark sometimes they won’t. Over the course of several exports different clips have been darkened and it hasn’t been consistent as to which ones. There doesn’t seem to be any pattern to when they do and when they don’t. Any suggestions on what is causing this and how to fix it would be greatly appreciated. This is my first project in Premiere. Thanks for any help.
