Clips are white
I have a problem. In the Viewer and Canvas windows, the clips are white. I can only see the images move the cursor on the viewer window or the bar on the timeline, but if I put play clip still white. In menu channels the RGB option is selected. In the windows that I said, the options Image, RGB and Black are also selected. In properties clip, if you have the alpha with none/ignore option and the composite with normal option, the clip is white in the viewer. If you put the alpha with straight option you see the clip in the viewer with dots and effects. But in canvas window clip still white when I put play. See the screen shot I made. The sequence properties have alpha with none/ignore option and composite with normal option. Can anyone help me, please?
