Clips adjusted with the effect, “Levels” not rendering
Hey All,
Using Premiere Pro CS6 6.0.5 and after doing my work using the effect, “Levels” to darken various clips, I go to render or export the clips for a finished video and everything seems to work fine, except my “Level” adjustments do not transfer to the finished video, I’m left with the original clips which were slightly over exposed.
I must be missing something regarding export settings. Has anyone out there run into this issue? Thanks
