Activity › Forums › Apple Final Cut Pro Legacy › clipping sound wmv
  • clipping sound wmv
    Posted by Donald Clark on August 30, 2010 at 4:17 pm
    Hello guys
    i have some wmv files that when imported into final cut pro are making a faint clipping sound.
    the actual videos themselves are fine when played in quicktime but they come with a clipping sound when imported into final cut pro, any advice?
    im using flipmac pro to gett he wmv files recognized
    Donald Clark replied 16 years, 1 month ago 2 Members · 3 Replies
  • Donald Clark
    August 30, 2010 at 5:27 pm
    ok thanks dave i’ll try that.
    Don
  • Michael Gissing
    August 31, 2010 at 12:41 am
    And make sure the audio is 48khz, 16 or 24 bit. When converting to ProRes422, make sure these are the audio conversion settings, plus your edit sequence should be also set to 48khz, which is digital video standard.
  • Donald Clark
    September 1, 2010 at 12:20 pm
    Hey thanks for that guys it worked look like it sorted out a batch export problem i was having as well cheers for the advice.
