Activity Forums Adobe Illustrator Clipping mask real size object
  • Clipping mask real size object
    Posted by Carlos Abellanosa on February 6, 2019 at 2:45 pm
    Hi all, this sucks… having a JPG image clipped in an object makes object size bigger, taking the JPG image boundaries rather than the object itself. That means any alignment or resize will take into account the clipped image size and not the visible size of the object. I made a screenshot for better explanation:
    Is it my Illustrator? Any way to get rid of this?
    Thanks in advance. Best,
    Carlos Abellanosa
    Kalleheikki Kannisto replied 7 years, 6 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    March 6, 2019 at 3:14 pm
    That looks to be a PDF file originally, and if so it is a clipping mask for the image. You can likely get rid of that container box by selecting it with the direct selection tool and deleting. That failing, you can try the Object>Clipping mask>Release command to separate the box and the contained image first and then deleting the unlinked box.
    Senior Graphic Designer
