Activity › Forums › Adobe After Effects › Clipping highlight signal
  • Clipping highlight signal
    Posted by Thiery Roussel on August 8, 2013 at 1:07 am
    .mov seem to have some clipping happening on import or export from after effects.
    i’m getting proresHq clip out of premiere to blur some face, and then i export for the grading in resolve in proresHQ. In Premiere CC, i see those overbright (above 100ire), they are not clip. But this doesn’t seem to pass on in after effetcs. I try with the original .MXF, no chance. I mess a lot with Color management. And same thing in CS6. So far, i drop my output white in 32bits to retain a maximum of signal for the colorist.
    But this is not a viable solution.
    I always thought i could import a .mov in after effects, then render in the same codec and obtain the same signal.
    What have I missed?
    thank you
    Thiery Roussel replied 13 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
