Activity Forums Audio Clipped Sound
  • Clipped Sound
    Posted by Christian Clark on October 8, 2010 at 9:51 am
    Is there any way to see the sound wave in clipped sound? Basically, it was recorded way too loudly and in FCP, all I can see is a block of clipped sound rather than an actual wave of low and high points.
    Thanks in advance for any help you can provide,
    Christian H. Clark
    City Limit Films
    http://www.citylimitfilms.com
    Peter Groom replied 15 years, 11 months ago 4 Members · 3 Replies
  • Ty Ford
    October 8, 2010 at 1:35 pm
    Hello Christian and welcome to the Cow Audio Forum.
    You can choose to see waveforms in FCP preferences. You can also export to Soundtrack Pro.
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Jean-christophe Boulay
    October 8, 2010 at 4:24 pm
    While FCP lets you see the audio waveform in the timeline, you don’t have a control over the scale of the waveform. Still, the FCP default waveform shows the complete resolution, so if you see a block with clipped tops, that is all there is to show. You can make your audio tracks taller in the timeline window to see better, but you’re not generating better resolution that way. If you don’t see the peaks of the waveform, it’s probably because they’ve been chopped off by the clipping.
    IHTH,
    JC Boulay
    Technical Director
    Audio Z
    Montreal, Canada
    http://www.audioz.com
  • Peter Groom
    October 11, 2010 at 1:29 pm
    Have you tried re recording the audio at the correct level?
    Peter
    Peter
