Activity › Forums › Adobe Illustrator › cliping path
  • cliping path
    Posted by Dreq on July 29, 2005 at 12:34 pm
    When i import a picture in illustrator cs and make a cliping path on it the previos picture bounds still remain and can be seen when in outline preview. Is there a way to get rid of them and keep only the clipping path bounds?
    I need this because when i make a pdf it makes it including this bounds too, and its generelly annoying.
    Thx in advance.
    Dreq replied 21 years, 2 months ago 2 Members · 2 Replies
  • Lazlo Hollyfeld
    July 29, 2005 at 2:49 pm
    Not sure if this would work, but you may have to export the Illustrator file as a layered PSD, then copy the bitmap of your image from the Photoshop file back into its proper place in Illustrator. It’s a complex work around, and there is probably a simpler way, but it may do the trick.
    Hope that helped!
    Arie
  • Dreq
    July 29, 2005 at 6:23 pm
    hmm i guess this would work, but i was wondering if there’s a simpler way to do this. Thx anyway
