Activity Forums Sony Cameras ClipBrowser 2.5/2.6 problems
  • ClipBrowser 2.5/2.6 problems
    Posted by Richard Browne on February 11, 2010 at 9:26 am
    Hi folks,
    I’m looking for a little advice. I have a problem with CB 2.6 – it won’t copy HD422 clips onto network.
    The workflow we operate is – transcode SxS to HD422 on ProDisc using CB, copy ProDisc to network drive as AMA Virtual volume using CB.
    The 2.6 problem is that, once on the ProDisc in HD422, when I try to copy clips from the disc I get the following error message:
    Failed to copy the clip.
    Reason: The file (folder) is not found. Please refresh information and try the operation again.
    I’ve tried different discs, and having pre-existing MXF folders or just empty folders at destination. I’m sure I’m missing something ridiculously simple but I never had this issue with 2.5.
    Any thoughts, help and nuggets of info greatly appreciated.
    Cheers
    Richard
    Richard Browne replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
