clipboard view?
Posted by Earle Del rosario on February 17, 2008 at 6:51 amI’ve searched in HELP, but can’t find steps. When cutting and copying, how can the clipboard be viewed?
Jerry Waters replied 18 years, 7 months ago 4 Members · 8 Replies -
Mike Kujbida
February 17, 2008 at 12:39 pmIt depends on what you want to do with it.
Do a search on clipboard in the Vegas manual and you’ll get several hits. -
Earle Del rosario
February 17, 2008 at 10:25 pmI’ve checked the manual, and it says that clipboard contents are seen on the VideoPreview. But, is there a window for Clipboard in particular, that displays the cut or copied event-portions?(Maybe a Clipboard window that looks similar to EditDetails, or MediaPool?)
Mike Kujbida
February 17, 2008 at 11:20 pm…is there a window for Clipboard in particular…
Not that I’m aware of – but I have been known to be wrong before so someone please correct me if I’m mistaken.
My main use for the clipboard is when I want to copy an image into Photoshop. -
Earle Del rosario
February 17, 2008 at 11:35 pmthanx. How can I make a still-image of a video frame on the timeline, aside from copying to Photoshop?
Edward Troxel
February 18, 2008 at 3:18 am -
Mike Kujbida
February 18, 2008 at 3:30 amCheck out Vol. 1 Issue 5 of Edward’s excellent newsletters for even more suggestions on doing this properly.
Earle Del rosario
February 18, 2008 at 8:45 pmgot it thanx.
VegasPro5,
P4 3.0Ghz HT,
Sapphire x600Pro graphics.
(Unless Vista is absolutely required, and until uncompressed video is edited, upgrading to dual or quad is wasting money. Concentrate on the work, not the toys — Example: Paul Thomas Anderson edited his first film using only two VHS decks.) -
Jerry Waters
February 19, 2008 at 12:19 amWhen capturing a still be sure you have the preview set to best and full before capturing. The setting of the preview (and, I think, the properties) determines the still quality you will get.
JerryW
