Activity Forums Adobe After Effects clipboard problem
  • clipboard problem
    Posted by Francois Moutou on March 25, 2009 at 5:58 pm
    Hello,
    I work on CS3 (AE + illustrator + photoshop + PP) and I have a recurrent problem with clipboard data.
    When I receive word documents, I save them as .rtf or .txt in order to copy/paste the data in text layers of Adobe softwares. Sometimes it works fine, sometimes it works for a while then stop and sometimes it doesn”t work at all. I tried copy/pasting with shortcuts, righ click + the edit menu so it’s not coming from shortcuts. People told me they have the same issue on other non-Microsoft softwares.
    I did my homework on adobe forums + on the Internet but did not find much info… just noticed I am not the only one having that problem.
    Since the problem disappears after a reboot, I assume it has something to do with memory or a max number of entries…
    Does anybody know a way around or a way to fix this?
    Thanx
    BTW: I work on PC / XP32 if it helps
    Francois Moutou replied 17 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
