Activity Forums VEGAS Pro Clip visible behind clip
  • Clip visible behind clip
    Posted by Kent Iler on December 10, 2008 at 2:57 am
    I have several video tracks in my current project. The video on track 2 was shot with a wide-screen camera, and I need to show parts of a clip from a standard format camera. What is happening is the I can see the wide screen format around the left and right sides of the standard format camera. I’ve played with video event pan/crop, but that only moves the video inside the standard format frame.
    How can I stretch the size of this to fill the entire screen. I understand I will clip part of the top/botton of the standard format clip.
    –Kent
    Kent Iler replied 17 years, 9 months ago 2 Members · 2 Replies
  • John Rofrano
    December 10, 2008 at 12:21 pm
    Go into Pan/Crop for the Standard Def clip, right-click on the frame (window) and select Match Output Aspect. This will crop the 4:3 footage to 16:9. Then adjust the crop so that your subject doesn’t have their head cut off.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Kent Iler
    December 10, 2008 at 12:26 pm
    Awesome! That worked perfectly.
    Thank you!
    –Kent
