Activity Forums Apple Final Cut Pro Legacy Clip Time Code to DVCpro
  • Clip Time Code to DVCpro
    Posted by Steve Hobbs on August 28, 2008 at 6:47 pm
    I need to record clips from the FCP timeline to DVCpro and the timecode needs to be from the clips not the timeline. Is this possible? I’m using AJA Kona 3 to Panasonic DVCpro AJ-SD93.
    More detail: I have imported footage from P2 cards and given the client a Timecode burn DVD. Now this footage needs to be given to a third party on DVCpro and still reference the TC burn from the DVD.
    Andy Mees replied 18 years ago 3 Members · 2 Replies
  • Rafael Amador
    August 29, 2008 at 2:07 am
    If you want the clip’s TC burnt in the picture, just drop the TC Reader filter.
    rafael
    http://www.nagavideo.com
  • Andy Mees
    August 29, 2008 at 2:09 am
    In future you might want to give them a burn in with both original clip timecode and your sequence timecode… then you would give them the dub with the sequence timecode. It may still be your best bet.
