Activity › Forums › Apple Final Cut Pro Legacy › Clip sorting
Clip sorting
Posted by Alexander Feichter on October 24, 2005 at 6:17 pmHello,
is there any way of sorting (sub)clips the ‘right’ way?
FC sorts the clips beginning at 1 then 10 then 11, 12, ….. 19, THEN 2, 21 …….Or can i tell final cut to do the increments with forestanding zeros?
Alex
Alexander Feichter replied 20 years, 11 months ago 4 Members · 6 Replies -
Jeremy Garchow
October 24, 2005 at 8:07 pmYou have to rename clips 1-9 with “forestanding zeros”
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.02 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre -
Alexander Feichter
October 25, 2005 at 8:21 amthanks for your reply, so i have to rename clip 1 to 99 with two leading zeros… 😉
would you prefer if final cut would add two or more leading zeros by default?
greetings
alex
Bouncing Account needs new email address
October 25, 2005 at 1:09 pm[alex_f] “so i have to rename clip 1 to 99 with two leading zeros.”
No.
Just 1 – 9. and only add one leading zero.
01
02
03
04
05
06
07
08
0920 will automatically show up next after 19 if you now have “2” marked as “02”.
Debe
October 25, 2005 at 1:29 pmYup. that’s the kind of thing you learn to do after something like this happens to you.
For the record, Avid doesn’t put leading zeroes in, either, unless you start out with them.
Likely you’ll use the zeroes in naming your clips from now on, eh?
debe
Alexander Feichter
October 25, 2005 at 10:02 pm🙂 thanks, man
ok, i have to clarify: dv-footage and scene detection. fc generates markers without leading zeros…
did you know that on the avid the subclips are sorted in the right order? 😉
