Activity Forums Apple Final Cut Pro Legacy CLIP SETTINGS command
  • CLIP SETTINGS command
    Posted by Neil Ryan on November 17, 2006 at 2:48 am
    Is there a keyboard command for ‘Clip Settings’ (under ‘Modify’ menu)
    I thought there was, but can’t find a reference to it.
    Occasionally log the wrong tracks on a clip, and find the pulldown menu method a liitle tiresome … wish it had shortcuts via right-clicking the cell, like other columns do …
    Thanks.
    Jeremy Garchow replied 19 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    November 17, 2006 at 3:00 am
    If you are in the bin, you can right click or control click on the clips and choose clip settings…is that what you mean?
    If that doesn’t work for you then make a key command or button for it by hitting option-j and type clip settings in the search bubble. You can assign a key command or drag the button to a button tool bar.
    You can only modify the clip settings from the bin.
    Jeremy
  • Neil Ryan
    November 17, 2006 at 4:15 am
    [JeremyG] “If you are in the bin, you can right click or control click on the clips and choose clip settings…is that what you mean?
    Yes, that’s probably what I thought I remembered – Great!
    [JeremyG] If that doesn’t work for you then make a key command or button for it by hitting option-j and type clip settings in the search bubble. You can assign a key command or drag the button to a button tool bar.
    And I like that, too (and have followed your idea and have DONE that, just now)
    Happy on both fronts!
    Excellent work, Jeremy.
    Take the rest of the day, off – you’ve done enough community work, today …
    A gazillion thanks!
    Neil.
  • Jeremy Garchow
    November 17, 2006 at 5:34 am
    …Shutting Down…
