Activity › Forums › Panasonic Cameras › Clip repair & Clip Re-connect
  • Clip repair & Clip Re-connect
    Posted by Nino Herr on February 4, 2013 at 3:54 pm
    Hi All,
    I am hoping you are able to help me with the following questions.
    We have a few HPX-372 cameras and I would like to know what the following functions in the THUMBNAILS> OPERATION menu actually do:
    1. Re-connect clip
    2. Repair Clip
    On several occasions some of our camera men have decided to do a battery pull whilst still recording. (Most stupid mistake known to man) The clip that they are recording during the time is obviously corrupted, as the file is not “closed off” correctly.
    Would a “Repair Clip” fix this type of problem? And in your experience, what are the limitations to clip repair and re-connect clip?
    Hope anyone is able to clear this up for me!
    Thanks a mill
    Nino
    Steve Eisen replied 13 years, 7 months ago 2 Members · 3 Replies
  • Steve Eisen
    February 6, 2013 at 1:10 am
    If you have a Red X on the thumbnail, you can repair the clip. P2 cards close the file every 2 seconds while recording. If repairable, the most you would lose is 2 seconds from a clip.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Nino Herr
    February 6, 2013 at 9:57 am
    Thanks Steve,
    It is comforting to know that the clip is saved every 2 seconds.
    Do you know what constitutes a clip that is repairable as opposed to one that is not? ie What can/cant happen in order for the clip to be repairable?
    Do you also know what precisely the repair clip function does? Ie does it re-write the lastclip.txt file with the correct info, whcih then in turn allows the cmaera to read the file again?
    Hope you can help!
  • Steve Eisen
    February 10, 2013 at 2:38 am
    There are 2 indications. Yellow X means the clip can be repaired. RED X can NOT be repaired.
    Steve Eisen
    Vice President
